Counter/Timer
positional count with 6036E and BNC-2110
Hello!
I've a problem with a quad-encoder connected to the bnc-2110 connector box. The box is connected to an 6036E card.
When I wire channel A of the quad encoder to the source pin (PFI8), GATE (PFI9) to +5V and UP/DOWN (DIO6) to +5V everything works as expected: No matter in which direction the encoder counts, values are reported as expected. But when I connect the channel B (90 deg phase shift) to the UP/DOWN-pin (DIO6), the negative values are twice as large as expected (the positive values are fine). What's wrong here?
Are the additional edges of the UP/DOWN-pin counted?
Is it okay to wire the encoder directly or do I need some small circuit in between?
Is this a special "mode" of the 6036? Configuration error?
Addit
ionally wiring the GATE-pin to the channel B does not help: the counter just counts in one direction afterwards (but those values are ok in both directions, just the sign is wrong!).
Is it a problem that some of the pins might be used as output-pins also? (this is not the case here, but maybe this is why it goes wrong).
I appreciate ANY help!
Christian
(3,385 Views)
Hello Christian,
in principle you don't need an additional circuit between your card and the encoder.
did you try to watch the signal of your encoder with a scope?
what happens, if you switch A and B signals?
did you connect the ground from your encoder to the ground of the card, to make sure to have the same ground level?
regards,
Robert H
(3,384 Views)
