Counter/Timer
problem with Counter
hi
A signal gives a correct value, if the speed is under 20km/h. above, somethime not correct. is there a opportunity to don`t show the incorrect value? I mean only the max. value in time?
(6,444 Views)
1. What is the hardware you use?
2. Attached VI.
(6,428 Views)
Hardware a microcontroller Arduino UNO (ATmega328) with LIFA. The Sensor is a reedcontact. Baudrate to Arduino is 115200 Symbol/second.
(6,426 Views)
Can you show us the actual measured graph? It might be due to the fast reading of the device, I would also recommend using some timing functions, as wait or wait until next.
Did you have a look at the examples? Are these working correctly?
(6,409 Views)
