Counter/Timer
problems with the function DAQmxSetArmStartTriggerType
I'm using DAQmx 8.3 and programming in Microsoft Visual C++ .NET
I encounter an error when building my solution, the offending function call being :
DAQmxSetArmStartTriggerType(taskHandle,'DAQmx_Val_DigEdge)
The error that is reported is : unexpected end of file in macro expansion
Has anyone seen this before? Thanks for any advice
(3,822 Views)
Hello IUBwork,
The function is expecting the following parameter:
DAQmxSetArmStartTrigType(TaskHandle taskHandle, int32 data);
I noticed in your line of code you had a " ' " in your code, before your DAQmx_Val_DigEdge. Was this in your code or was this a type-o in the discussion forum?
  Sandra T.
Applications Engineer | National Instruments
(3,812 Views)
Hi Sandra,
Thank you for the assistance. The errant, ' , was in my e-mail, and not in the code.
This morning I tried to repair (via the MS Windows "Add or Remove Programs" Control Panel facility) my DAQmx 8.3 version. This has ameliorated the problem. Perhaps there was a 'hiccup' during my installation.
(3,806 Views)
