Counter/Timer
pxi 6602 pulse generation
Hi i am new user and i got pxi 6602 iwant to generate a 5 khz 3.5ms 2.5 amplitude and 2.5 offset i probably need to use 2 counters can someone tell me which wires i need to connect on scb 68 device and how ican write this program?
Thanks for helping me
(6,173 Views)
Did you read the specs before buying the device? You can't use any counter, let alone two. The device has TTL compatible signals so no amplitude or offset control. A card with timed analog output would work.
(6,157 Views)
Thank you dennis but 2.5 amplitude and 2.5 offest gives a5v pulse and this device can generate 5v pulse
(6,151 Views)
Accepted by topic author simtatoren19
It can generate ttl which means a 0 to 5 volt pulse. If that fits your definition, then it will work.
(6,149 Views)
it fit my definition but ican generate the pulse without delays between clearing and starting over the task in while loop
(6,143 Views)
