Counter/Timer
reset counter 6601
In my application I'm working by examples of type "Count Digitl Events..." because i have to count in a  interval time. But in this examples the counter accumulate and make to grow the result number. Instead i want a counter that in every cycle begins to count from zero. What can I do it ? How can I modify the examples in disposition for my aim ?
(5,432 Views)
An Applications Engineer is working on this issue and has proposed you a solution. You need to use the Z index to reset the counter. It is fairly easy and well documented with the NIDAQmx driver.
AlessioD
NI
PS: Following is the list of Forum threads you started over the last week. They are all identical and related to the reset counter issue you are discussing with our AEs.
1- http://forums.ni.com/ni/board/message?board.id=40&message.id=3784#M3784
2- http://forums.ni.com/ni/board/message?board.id=7170&message.id=40#M40
3- http://forums.ni.com/ni/board/message?board.id=40&message.id=3785#M3785
4- http://forums.ni.com/ni/board/message?board.id=70&message.id=5163#M5163
5- http://forums.ni.com/ni/board/message?board.id=280&message.id=1972#M1972
6- http://forums.ni.com/ni/board/message?board.id=40&message.id=3786#M3786
(5,421 Views)
Donnola,
can you sen me your programma.vi, saved in the LV 7.0 version? (File->Save with options). I have done the upgrade to LV 8.0...
Thank you.
(5,402 Views)
this the program
(5,398 Views)
still can't open your VI
are you sure you saved it in 7.0 version?
tx
(5,396 Views)
(5,392 Views)
still not!
you saved it in a 7.1 version, and I use LV 7.0!
can you please send it again?
tx
(5,386 Views)
