Counter/Timer
route RTSI line to channel z
Can I route a RTSI-line to the index/z - channel of a 6602 counter when it is conigured for position measurement?
In Labview "set attribute" only offers "gate" as input option and this doesn't seem to do the job. Can anyone offer a solution to this?
Gi
(3,153 Views)
Unfortunately, no.  The z-channel has to be a physical wire connection directly to the counter's default GATE input.  What is the source of the RTSI signal you'd like to use?  Are you unable to run a wire?  Hope you can find a workaround...
-Kevin P. ,  wishing NI would provide a more complete set of z-index-like capabilities to enable functions such as resetting counter value with a hardware pulse.
(3,150 Views)
