Counter/Timer
single pulse width measurement
Sucess!
The "Digital Filter" and changing the task to "Pulse Width" has led to repeatable measurments on all of the counters and different PFI inputs.
I have attached some images of the final results.
Message 11 of 12
(2,624 Views)
In case anyone else needs to know:
This pulse measurment is for determining the time between two optical gates, so that the velocity of the striker can be determined on a tensile Split Hopkinson Pressure Bar.
The PXIe-6361 is being used for collecting the measurments of the optical gates and from the pressure transducer.
A PXI-5105 is being used to gather data from the strain gauges.
Message 12 of 12
(2,623 Views)
