06-22-2006 01:50 AM
06-22-2006 09:45 AM
06-23-2006 11:27 AM
Hi Kevin,
Thanks for your kind support!
Do you mean "External sampling clock" is the step trigger command generated by software itself or other external triggering source?
Basically, I do understand your idea but if you can provide me some samples or explain more will be highly appreciated?
Thanks a lot...![]()
06-23-2006 02:20 PM
Re: "external sampling clock."
The finite position measurement task will need you to specify the source signal that acts as the sampling clock. You can do this with DAQmx Timing.vi Because the sampling clock is a signal from the external world rather than a singal internal to the board, I referred to it as an external sampling clock. Some of the shipping examples use that terminology too.
I don't know where the step pulses are being generated, but you can use them whether you generate them yourself in software or whether they come from elsewhere.
Also, note that a "sampling clock" is considered as something quite different from a "trigger" in data acq. Nothing about your app sounds like it needs to concern itself with a trigger.
-Kevin P.
06-24-2006 07:46 AM
06-25-2006 06:05 AM
Hi Kevin,
I wonder If there a way to do step angle measurement without using external sampling clock? For example using the phase A,B detection direct from the encoder.
Thanks advice.
06-26-2006 04:48 PM
Hi Simon,
You can take a look at the example "Measure Angular Position" in the NI Example Finder (Help >> Find Examples in LabVIEW). It does not use an external sample clock so hopefully it will be useful to you.
Laura
06-27-2006 09:10 AM
06-28-2006 09:51 AM
08-03-2010 12:18 PM
hello,
i want to move a unipolar stepper motor(24v ,0.6A) in SHM......(+90 TO -90,+80 TO -80......)
i hope u hav got it..as i thnk there shld nt b ne modification in d circuit.it can be connected juz noramally.
i m using L293D as a motor driver.
i m nt gtng d xact concept for d programming part
cn u plz help me giving a logic..???
plz rply as soon as possible..itz a lil urgent.....
regards,
milind agarwal
