Counter/Timer
subvi
I want to create a function which takes only one vi path as input even though it has many controls and indicators . how is it possible.
For example i attached my code and the type of calling function i want . please explain
(6,432 Views)
Accepted by topic author mahi108
Hi
You can do that by attaching only the VI path control to the connector pane when the subVI is being created and not all the controls and indicators. Is this what you wanted or did you want something else?
regards
Flacon
(6,417 Views)
Thank you kudos sir
(6,415 Views)
HI
Thank you. However, you might wanna click on the kudos link as well 😄
Regards
Falcon
(6,412 Views)
