Counter/Timer
tab constant ?
under strings what is the diff b/w
Tab const
line feed const
carriage constant
end of line constant
if possible explain with a small example please
(6,157 Views)
Accepted by topic author Nagaa
These are just replacements for writing ASCII codes. For instance, If you want to write some text, and you want to input :
A Tab space ( \t ) : you use TAB constant
New Line ( \n ) : you use LINE FEED constant
Carriage or Enter ( \r ) : you use CARRIAGE constant
End of line ( \r\n ) : you use END OF LINE constant
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(6,153 Views)
Thank u sir
Best regards
nagaraja
INDIA
(6,147 Views)
