Counter/Timer
tell me the EASIEST way to read a quadrature encoder into degrees.
I have a maxon brushed DC motor, and it has an encoder on it.  I'm pretty sure it's quadrature.  I have no NI hardware, so i'll buy some.  I would rather buy USB or PCMCIA hardware.  what's the easiest way to do this?
(3,463 Views)
I recommend to use a M series DAQ card to read the encoder. An example of an angular position measurement ships with LabVIEW --> ..\LabVIEW X.X\examples\DAQmx\Counter\Measure Position.llb\Measure Angular Position.vi
Do you also need to control the motor through LabVIEW and NI hardware ?
(3,455 Views)
