Counter/Timer
time stamp does not update automatically
Hi, All. I want include the time stamp (yyyy-mo-dd-min-sec) in the file name. However, the value of the time stamp does not update automatically/synchronizes with the computer clock at each new run. I need to do it manually with the right click and update the time to the current.
How can I solve this? Thanks a lot in advance.
(4,134 Views)
What does this have to do with NI counter/timer hardware?
What language are you using and what function are you using to get a timestamp? If the language is LabVIEW, then all you need is Get Date/Time in Seconds. If you are using a front panel Time Stamp control, then you are using the incorrect function.
(4,127 Views)
