Counter/Timer
trying to trigger multiple analog measurements with each pulse of a 500PPR encoder
I am trying to take multiple analog measurements form 6 sensors with each pulse of a 500 ppr encoder and write these to a file.  Problem I have run into is I am not getting 500 readings with 1 revolution of the encoder the most I have received is 187 however this isnt consistant.
using
6024 E Series card
BEI L25G encoder
Still relatively new to labview along with using an older version 7.0
Thank You in advance
(4,635 Views)
Accepted by topic author LabTech09
Never mind after looking at it somemore i found i was using the wrong sample rate
(4,633 Views)
