Counter/Timer
visualising digital output on a plot
Hi,I am programming digital output using counters in LabWindows, I use DAQmxCreateCOPulseFreq function to send continous digital signal to the output channel,
to verify if the program is working fine, before I connect hardware, I would like to make a plot of the signal which I generated using a counter,
does anyone know about function displaying counter/clock itself? Thanks
(5,875 Views)
Hi Joanna,
Would you be able to post your code or provide a screenshot? The "Cont Write Dig Chan-Burst.vi" code from LabVIEW example finder shows the digital output as it is written to the channel- this might help
(5,845 Views)
