Counter/Timer
why the start trigger not supported in my counting edge vi
Hello All,
    Please see my attached vi. My goal is to start 2 counter counting simutaneously. A PFI line is used as sampling clock which I will input some pulse train. As my E series DAQ-card doesn't support arm trigger, I have to use two start trigger. but there's error when I run it:
Error -200452 occurred at Property Node DAQmx Trigger (arg 1) in DAQmx Start Trigger (Digital Edge).vi->sync counter v2.vi
Possible reason(s):
Specified property is not supported by the device or is not applicable to the task.
Property: Start.TrigType
Task Name: _unnamedTask<E>
   Can
(3,371 Views)
Please refer to this thread.
Thank You,
Nick F.
(3,366 Views)
