Counter/Timer
wire an external clock to a timed loop
Hello
I`m trying a lot but this simple task doesn`t work.
I have an USB-6251.
I will count pulses in a time specified by an external clock.
The attached VI works only with the software clock.
Every try ends up in an error message.
Can someone told me how to add a port where i can physicaly wire my clock?
I will use my to counters for counting so i cant use them as inputs for the loop.
many thanks
Message Edited by Joan@DLR on 07-27-2007 05:51 AM
(3,944 Views)
Hi Joan@DLR,
here is an example, where an external clock is used for the timed loop.
Best regards
Dippi
(3,924 Views)
