Counter/Timer
write to digital line and wait 20 mico sec and aquisition
i have DIO-32HS and PCI-6036E. i want to select a port by writing to digital port or line and then wait for 20 micro sec after thar i have to aquire data from AI.my problem is waiting 20 microseconds how i can achieve this?E-mail id:ksvreddy@iitk.ac.in
(3,312 Views)
Here is what I suggest. I'm assuming you will use the DIO-32HS for writing to the digital line. You could use that digital line as a trigger for a counter on the PCI-6036E. When the counter is triggered, it could generate a single pulse with a delay of 20 microseconds and that pulse could be used as a trigger for analog input on the PCI-6036E.
There are LabVIEW shipping examples that will illustrate how to setup triggered counter and analog input applications. I hope this helps.
Todd D.
(3,312 Views)
