DAQExpress
18+ channel 24+bit data acquisition system to acquire ICP and voltage inputs
I need a data acquisition system for my research work. I need an 18+ channel 24-bit data acquisition system which can acquire in both ICP and Voltage type inputs with AC or DC coupling from 0 to 20000 Hz frequency without multiplexing. I need at least two AC output on the system. Can you suggest me the system along with its pricing and/or specification? If the AC/DC coupling and or ICP are not inbuilt in the system, please suggest the additional equipment by NI including wiring requirement for the same.
Thank you.
(3,997 Views)
Hi aapine,
Thanks for reaching out with your questions. If you are looking to discuss product recommendations and system set up, it would be best to discuss this with some of our sales engineers. They will be the best place to get pricing information, whereas forum are for discussion of technical questions.
You can reach them via email or phone through the contacts on this page:
Contact Us - http://www.ni.com/contact-us/en-us
Do you know what form factor you are looking to use? If so, you can do some searching in the link below to determine what modules can fit your needs. You can restrict your search by the type of signals you are looking to acquire in the DAQ section.
Shop - http://www.ni.com/en-us/shop.html
Hope this helps!
Erika
Technical Support Engineer
(3,927 Views)
