DAQExpress
Analog Output Multiple Square Waveforms on NI cDAQ-9174 with two NI 9264
I am trying to create a program that will allow me to output single square waveforms across multiple analog outputs similar to the Simple FGEN.gvi file given as a tutorial example within DAQExpress. Below is an image of the diagram of the tutorial example:
DAQExpressSimpleFGENDiagram.PNGWhen I try to add multiple channels (second image below) in the Function Generator.task file i get the following error:
When I remove Output 1 the program runs but it will only output a single waveform to Output 0 where my goal is to utilize all 36 outputs of my two NI 9264.
Here is my hardware specs:
  • Windows 10
  • DAQExpress
  • NI cDAQ-9174
  • 2x NI 9264
Thanks in advance!
Message 1 of 1
(2,544 Views)
