DAQExpress
How to connect a NI-9361 counter input module with a NI-9171 USB cDAQ ?
I don't manage to connect my NI-9361 counter input module with a NI-9171 USB cDAQ.
I've updated all the NI-DAQmx drivers to the 18.0 version.
Thank you,
(5,079 Views)
As I can see on the screeshot, there is an issue to detect the hardware in MAX ?
Have you try to connect the cDAQ-9171 on another USB port ?
The DAQmx version is good.
Could you add a screenshot when you select the cDAQ-9171 on MAX to see what is the message at the right of the window ?
Have a good day
Eloise
NI France
(5,042 Views)
Yes, I tried all the USB port of my computer.
I attached the screenshot.
Have a nice day,
(5,040 Views)
Thanks for your reply.
Could you try the steps on this KB :
Can't Find DAQ Device or Module in LabVIEW And/Or Measurement & Automation Explorer (MAX)
Eloise
NI France
(5,036 Views)
Hi Eloise,
Thank you for your answer.
I tried all the steps, but I don't manage to force the driver on my computer, even selecting the file directory where NI installs the drivers. I Attached screenshot.
(5,027 Views)
Could you test the cDAQ-9171 on another computer ?
Could you change the USB cable ?
Have you another NI Hardware USB to test on your computer ?
Have you USB 3.0 port ?
Device Manager Not Recognizing USB DAQ Device When Connected Through USB 3.0
have a good day
Eloise
NI France
(5,024 Views)
