DAQExpress
Output trigger
Hi there,
can anyone tell me how I can output a simple TTL pulse? Is there an example code which I overlooked?
Thanks for your help!
(4,179 Views)
Hey Marius, gneratinbg TTL signals depends on the hardware you use. If you go to the LabVIEW examples in Hardware Input and Outpu>>DAQmx>>Digital Output>>Digital - Continuous Output.vi
(4,143 Views)
