DAQExpress
Periodic Logging on DAQExpress
Hello everyone,
I've been working on a small project to read voltage from an analog source, and DAQExpress already had a sample project file to do Periodic logging from a sensor measurement.
Now, I am getting way too many numbers on the TDMS spreadsheet when I open the log up. I played around with the "Desired Sampling Rate" and "Samples to Read" and can't figure out how I would lower the amount of samples to much much lower.
All I want to be able to do is, have this project run constantly 24 hours a day, but log 1 hour of data, but only record like 1 data point every 15 seconds so that I don't get a bunch of numbers on the TDMS file.
I assume I have to use the triggering function, but what about sampling rate?
Any help would be appreciated!
(3,635 Views)
Any luck on this?? I have encountered the same issue /.
(3,507 Views)
