DAQExpress
Post-processing : how to extract the mean of several captures at once in DaqExpress ?
I am a new user of DaqExpress and I need help with my Post-processing.
After my acquisitions, I capture my different areas of interrest (the data set is too big), then I display the mean of my first capture (using the "statistics" analysis panel) and I write it in a CSV file. I repeat the same for the other captures (60 captures in total).
Is there a way to automate this task in DaqExpress : export the means of differents captures at once into a CSV file ?
My data are acquired from strain gauges.
I hope I have been clear enough in my explanations, Thank you in advance for your help.
Message 1 of 1
(1,834 Views)
