DAQExpress
Solenoid valve control
I am fairly new to LabVIEW. I am using USB-6211, and want to control the closing time of a normally closed solenoid valve changing the voltage supply from the analog output of DAQmax using a defined sequence. For example, I want the voltage change like [5,6,8,10] how can I do this to activate different optocoupler/ relay that will close the solenoid valve at a different rate of time. Can I use an array to control the output voltage with DAQ assistance? Or is there another way?
Many thanks in advance!
Message 1 of 1
(2,686 Views)
