DAQExpress
Syncronise digital and analog tasks
I need to log digital signals from a USB 6009, while reading analog signals from another USB 6009. How can I set the digital logging to match the sampling of analog signals? There was a similar thread already but the links are broken now.
https://forums.ni.com/t5/DAQExpress/Linking-analog-and-digital-tasks/td-p/3907221
(2,505 Views)
Hello there!
A simple google search led me to these articles. Hopefully you will make use of them.
NI-DAQmx Data Acquisition Triggering Techniques Using LabVIEW
Synchronization Explained - NI
Timing and Synchronization Features of NI-DAQmx - NI
There is also a forum post that might come in handy.
Solved: Re: Synchronizing Digital output, Analog output and Analong Input using Ni-DAQmx - NI Commun...
(2,429 Views)
Thank you for your hints. I did not mention that I use DAQExpress. There are many examples I found, but they are not relevant to DAQExpress, which is pretty different.
(2,419 Views)
Hi again.
Indeed, the links I provided are related to DAQmx, but the principle behind synchronization is still the same. With DAQExpress, you need to set up a trigger which will sync up all the inputs and outputs. Please refer to this article to set up your trigger:
Counters and Triggers Using DAQExpress - NI
Please make sure to watch the videos in the article as well, I think they will help you understand the concept of synchronization by triggering better.
Let me know if you need further assistance.
(2,401 Views)
