DAQExpress
how to aquire signals from two channels simultaneously ?
I want to use DAQExpress VI to config a task which can read signals from two analog channels simultaneously.
The node: Task constant, can be used to select or create a task.
But when I create a new task, the panel only allows me to select one channel.
How can I config it to acquire data from more than one analogue input channels simultaneously?
Thanks for your help.
Penn
(3,859 Views)
Accepted by topic author Dr.Penn
Hello Penn,
You only can select a channel in Channel dropdown menu.
If you want to add more Input, you can create new inputs from "Create New Input" button under the graph like below.
(3,815 Views)
Hello Y.Ueno:
Great.
Thank you.
Penn
(3,797 Views)
