DASYLab
Analog Output Errors with PCI-6251 Driver in DasyLab 10.0
Hi Ryan,
If you run the continous output task from MAX directly, does that show up properly on your scope?
Hassan Atassi
Senior Group Manager, Digital Support
Message 11 of 14
(3,026 Views)
I used the analog output to generate a pulse and it was up to 5 KHz.  That gave me a beter control for the phase.
This is the one I used but they have a model with 2 out
http://www.mccdaq.com/usb-data-acquisition/USB-1208HS-4AO.aspx
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 12 of 14
(3,023 Views)
Hi Hassan,
Yes it runs a continuous sine/square/triangle wave.
CJ - Do you have an email to contact you with, or a toll-free #. My lab doesn't have access to long-distance or international calling
-Ryan
Message 13 of 14
(3,021 Views)
Hi All,
I just want to thank you for all of your hard work in helping me find a solution. David Fraska was able to find a solution for me. I needed to reset through Measurement->Hardware Setup->nidaqmx->synchronization with MAX configuration. This has allowed me to finally send out the pulses that I wanted.
Thank you again,
-Ryan
Message 14 of 14
(3,016 Views)
