DASYLab
Are there DASYLAB 6.00.07 hardware drivers for the NI USB-9215
I'm working with Dasylab 6.00.07. Do you know whether there are allready any hardwaredrivers for the NI USB-9215 ?
(10,162 Views)
At this time, DASYLab only works with NI hardware via the traditional NI-DAQ interface. Any board that is not supported via NI-DAQ will not work with DASYLab V8.
The data sheet for the USB-9215 says:
USB-9211 and USB-9215 devices each come with a ready-to-run
data logger application that acquires and logs up to four channels of
analog data. For more functionality, the NI-DAQmx Base driver
software is a multiplatform driver with a limited NI-DAQmx
programming interface.
This says that it is not supported via NI-DAQ, and is not currently supported by DASYLab.
We are actively working to ensure DASYLab's support for the DAQmx interface - watch for updates of the software!
Please note that new driver support, such as this,
will require an upgrade to the released version of DASYLab. It is not possible to update V7 or earlier with the changes required to fully support DAQmx.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(10,161 Views)
Thanks CJ, for your speedy answer. It's seems to me the combination of the simple 4-channel USB-9215 with the Dasylab software is made for eachother, so I'm very interested in new driver update of V8. Could you roughly estimate when I can expect this to happen?
(10,161 Views)
Unfortunately, I cannot comment on a release date. All that I can say is that we consider it a critical update, and are actively working on it. Because of the nature of the changes required to work well with DAQmx, we want to ensure that it is fully implemented and carefully tested before release.
-cj
(10,162 Views)
Thanks for your answers, I'll keep an eye on it.
(10,161 Views)
Hello CJ (or others),
could you please give me an update on the status of the new NI-DAQmx driver for Dasylab?
Ton
(9,880 Views)
CJ
correct me if I am wrong, but the NI 9215 just is supported by the NI DAQmx Base driver, which will not be part of the upcomming DAQmx driver from DASYLab.
(9,872 Views)
