DASYLab
CTR08 Reset Counter
I am trying to use a CTR08 with an E1608 and DasyLab.  How do I reset the counter on the CTR08?  With DasyLab and the E1608 counter, I can just use an Action node to "Reset Counter".  This isn't working with the CTR08.  Is the only way to do it through the gate input on the CTR08?
Thanks in advance.
(4,405 Views)
You should check with Measurement Computing on this.
There is a feature/option in the DASYLab 2016 driver, where you can use the gate to clear or reset the counter, or have it clear the counter each time it reads it (no gate).
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(4,380 Views)
Thanks CJ, I just spoke with MC and apparently I cannot use the fancier features of the CTR08 from within DasyLab.  The gates will do.  Thanks.
(4,361 Views)
