DASYLab
Can I show a video stream at DASYLab11 ?
I would like to show a webcam video stream into a DASYLab layout . Is it possible ?
(5,997 Views)
No - DASYLab does not have a way to support a live video feed.
If you wanted to write an Add-on to DASYLab using the Extension toolkit that provides that, it might be interesting. I don't know how well it would work with the layout. Usually we suggest that you look at a product like LabVIEW for multimedia features like that.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,982 Views)
Thanks CJ, I'll check the extension toolkit, but I believe it will take some time to be developed. If I come with a solution, I will be glad to share.
Rodrigo.
(5,979 Views)
A work around would be to use another application, eg. MPC-HomeCinema ( h.ttp://mpc-hc.sourceforge.net/).
With MPC-HC it's possible to "undecorate" (no borders) the window, which show the webcam's vision, and make this window always-on-top, too. Reserve a little space in the layout and move the webcam-window onto this space.
*tadda*
(5,968 Views)
