DASYLab
Channel changing
Yes, the MAX export file *.nce with included tasks and device would be more helpful.
Message 11 of 15
(3,558 Views)
I tried to attach the .nce file and it gives me an error saying that its not an acceptable extension for an attachment.  What would you like me to do
Message 12 of 15
(3,553 Views)
Please 'hide' the NCE-file in a ZIP-archive.
BTW:
May be a nice augmentation to this NI-forum, if it's possible to attach files-formats used in NI-software... 😉
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
Message 13 of 15
(3,549 Views)
Attached is the NCE file.  Sorry for the delay, I've been on vacation
Message 14 of 15
(3,535 Views)
@djmac,
I have used your configData1.zip MAX settings and your last DASYLab worksheet. I'm use DASYLab 12.0.x and get from DASYLab NI-DAQmx driver an error message if I load the DSB:
- task MyVoltageTask -> The synchronization load from MAX into DASYLab say me that the task have an internal sampling rate = 0.0. This based on an error from NI-DAQmx API outside from DASYLab. A workarround is only if you change the MAX task mode "continuous" into 1 value spoftware polled. Is this possible for you? Please check now the swapping situation for your application.
MHa
Message 15 of 15
(3,521 Views)
