DASYLab
Como se puede realizar run a varios archivos .DSB simultaneamente
Tengo varios archivos DSB, y quiero realizar run a todas para que me simulen simultaneamente.
(5,634 Views)
DASYLab can only run a single instance at a time, with a single worksheet.
If you need a more complex environment, you may need to move to LabVIEW.
A single DASYLab worksheet can work with multiple devices, and using the DASYLab Full/Pro feature set, you can run multiple data flows simultaneously in one worksheet.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,632 Views)
