DASYLab
Concatenating numbers with leading zeros into a global string in DasyLab
I need to format a global variable into a global string with the field width exactly three characters long. For example, if the global variable is 1, the global string needs to be "001". I tried using strfmt(${VAR_801},3,0) as the expression under the extended global string dialog, but that results in "1". Any help or suggestions are appreciated.
(7,864 Views)
Hello Mark,
DasyLab support is handled through the following website.
DASYLab
www.dasylab.net
Todd D.
NI Applications Engineer
(7,864 Views)
