DASYLab
DAQCard E Series
I've been tried use the DAQCard-AI-16XE-50 with Dasylab. I read in documentation the driver that support this device is restricted to Traditional NI-DAQ (Legacy), so I use this NI-DAQ. My problem is how to configure the OPC server to access the data card. Where can i find a tutorial to do that?  Are there other ways to use this card with DASYLab?
I hope you could help me with this problem.
Thanks in advance.
(6,233 Views)
Ok, I solved the situation thx to this tuto. I created a virtual channel in Data neighbordhood and setting the correct parameters.
I hope that be usefull for anyone in future.
(6,229 Views)
Just to close this thread -- use the NI-DAQ DASYLab driver, not OPC, to communicate with any device that you need to use its full features and speed.
When installing DASYLab, you must specifically select the NI-DAQ driver, and de-select the NI-DAQmx driver. You can always re-run the installer to make the change.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,202 Views)
