DASYLab
Dasy Lab 10 Data Stream Blocked
CJ,
I have some other stuff going on this afternoon will you be in Monday?
Message 11 of 13
(3,116 Views)
I should be. Hopefully you can be at the computer, and the computer is on the internet.
I'm wondering how the ODBC connection is made, and if updating it 8 times a second is too much.
I can't reproduce that here - I just made a quick Excel sheet to run.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 12 of 13
(3,114 Views)
Just adding my two cents to this thread in hopes it'll help someone else. I had the same problem and used the clues in CJ's response to work around it.
My issues were also with Relay modules. Re-drawing the wires didn't help. However, dropping my block size down from 32768 to 10000 seems to have done the trick.
Message 13 of 13
(2,976 Views)
