DASYLab
DasyLab 10 and worksheets from DasyLab 9
After updating to DasyLab 10 from 9 (more of a minor update than a major upgrade from the look  of things so far), I am seeing a driver error when loading worksheets from 9.  If I tell DasyLab to just use the version 10 driver, it will work, then using "Save as", the worksheet will work the next time.  The thing is, I have 85 worksheets from version 9 that will have to be re-saved.  It can  be done, but does anyone know a quicker way to accomplish this?
Thanks for any help, and for the forum.
(7,515 Views)
I have come up with a workaround to the driver problem.
Since the DasyLab 9 worksheets are looking for a DasyLab 9 directory, I created one.
There is only one file in it -- a copy of the DasyLab 10 driver file.
The worksheets open fine now, and seem to work the same in DLab 10
(7,511 Views)
I'm glad that you sorted it out.
It was impossible to answer your question without more specifics of the error message and hardware configuration.
In general, for hardware errors such as this, you should contact your DASYLab reseller or your hardware vendor. They may have been able to give you answers much more quickly.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,480 Views)
