DASYLab
DasyLab 9 IxxAT CAN-Error
Hello
I use DASYLab V9 Full (9.00.01) for read and send data from/to a digital signal processor. For the data transmission, I use the USB-to-CAN interface from IxxAT. I create 10 different dasylab-worksheets, which I connect it all together to a flow controll. So, most of the time, my program works correct without any errors. But sometimes, the following error-messages are shown:
IxxAT-CAN Error in file: _CAN_InitExperiment_IxxAT-CAN.h, line: 323     ERROR: -2
IxxAT-CAN Error in file: _CAN_InitExperiment_IxxAT-CAN.h, line: 358     ERROR: -3
IxxAT-CAN Error in file: _CAN_InitExperiment_IxxAT-CAN.h, line: 397     ERROR: -2
Then I must restart DasyLab so that I can start data transfer again. The error appears between switching of worksheets, but absolutly accidental. Capturing data with 100Hz (Block size: 10).
I use Windows XP SP2 and the newest driver from IxxAT (CAN 711, DLL version: 8.11)
Have you any advices or solutions for me?
Best regards
E. Hermann
Message 1 of 1
(8,029 Views)
