DASYLab
DasyLab V6 to 9 Vs DasyLab V10
I'm testing the DasyLab V10 SP1 with my old worksheets from DasyLab V6 under WinXp and 2k.
I have V6, 8 and 9 version of Dasylab.
I started the validation of my worksheets (under V6) with DasyLab V9 last year (before the V10).
=> In generally all was OK
But now, as the V10 is available, i try this new version and ...
=> In generally all was OK but ...
... The time necessary to load the Layout is multiplied by 10 (as the version !!)
The Vista compatibility change a lot about the graphic interface management.
There is a configuration to do or a modification of the DasyLab.ini to do to optimize this time ?
Actualy the V10 isn't adapted for my application (until 30 layouts to load).
Thanks a lot
Debruyne
(7,785 Views)
The first time that you load an older worksheet, it must be converted to the current format.
When you save it as the *.DSB file for V10, the next time, it should load faster.
If this is not the case, can you attach an example file for me to look at? I would need the earlier version worksheet.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,784 Views)
