DASYLab
DasyLab11 Datatype word
Hi
I 'm trying read the information of one power meter with output RS485 Modbus RTU  I 'm using the Modbus Analog Module and I have done the test for communication for it and the test is good but after as I can to read the information on digital meter Module or to make chart recorder. I have tried wiring directly after of the Modbus Analog input. Could you help as I can to make this application.  Thanks
(6,225 Views)
Accepted by topic author rolmale
I am not sure that I understand the question.
DASYLab V11 SP2 delivered a completely revised MODBUS module -- what version of DASYLab are you using?
Can you tell us what the device is, what the data type is, and how the bytes are stored (Motorola vs. Intel format).
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,193 Views)
