DASYLab
Dasylab 16 - python script : operation on two inputs and one output
I'm trying to create a python script to do a special operation on two numbers, and I want to output this single result on the module.
I took a look at some samples, and on this question.
I successful created a simple script that does output = input * A + B (A and B two internal parameters of the module).
I'm more looking to combine inputs by doing something like output = inputA * InputB (the reality is more complex of course).
So my script is for now like this :
def DlgInit (self, dlg):
# Initialization of settings dialog
# Click on the help button to get more information.
self.NumInChannel = 2 # amout of connectors on modules left side
self.NumOutChannel = 1 # amount of connectors on the right side
self.DlgNumChannels = self.NumInChannel
self.DlgMaxChannels = 1 # Ly.MAX_CHANNELS
def DlgOk (self, dlg):
self.SetConnectors(self.DlgNumChannels *1 , self.DlgNumChannels /2)
And it displays fine.
But now I'm stuck on how to code the ProcessValue module. How to reach the two inputs value in the same call ? It looks like I'm not thinking the right way on this.
And please note that when I try to run my sheet, DL says that the internal script structure is damaged...
Any advice ?
Thanks !
Benjamin
Message 1 of 1
(2,535 Views)
