DASYLab
Dasylab 7/9 PCI-6143
Is it possible to control a PCI-6143 (S Series Multifunction DAQ) with Dasylab Version 7 or 9?
Thank you.
(6,782 Views)
Use the DASYLab 9 DAQmx driver. The V9.0.2 readme says this:
·     National Instruments NI-DAQmx Driver
To use the NI-DAQmx modules in DASYLab, you need the hardware driver NI-DAQmx API Version 8.3.1 for Windows 2000/XP dated 21.11.2006 from National Instruments. You can find these drivers on the National Instruments webpage ni.com.
 Note that if you have any problems, especially if you are using a current release of NI-DAQmx, you may have to update the DASYLab software to Version 11.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,781 Views)
