DASYLab
Dasylab: Use with LIN Bus Interfaces (USB-8476)?
Hello All,
Does anyone know if Dasylab can be used with any LIN bus interfaces (e.g. USB-8476)?
If this is possible, can Dasylab support several of these devices simultaneously?
(4,050 Views)
To be honest, we're not sure. I don't have any testing of the NI LIN devices with DASYLab 2016 or DASYLab 13.
It's is very likely that it will work, but it will take some research to verify it for you.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(4,013 Views)
Hello CJ
Thanks for the reply,
My questions are twofold....
1). Does Dasylab have specific modules to support LIN & its 'LDF' files (similar to the way Dasylab has a specific module for CAN & its CANdb files). From what I can see, it appears not?
2). If Dasylab IS able to support LIN, can it cater for multiple instances of a LIN interface (e.g. like the USB-8476)
Is there anyone available within NI to assess this & let me know for sure?
Thanks & Regards,
(4,001 Views)
