DASYLab
Dasylab v12 - E-Mail Module
In the scope of a continous and long term measurement, I would like to use Dasylab E-Mail module to send regularly an email (once a week) by SMTP method with the current status of my mesurements... I have already found some old  discussions about E-Mail module and I didn't have my answer. I think it's not possible with Gmail and my test doesn't work (e-mail serveur smtp.gmail.com / e-mail port 567, error message: the e-mail coulnd not be sent. The actual sending has caused an error). Which email server can I use ? Is there a possibility to get a status to push directly in the e-mail content ?
Thank you in advance and best regards,
(5,719 Views)
Using SMTP requires that the sending PC is member of a company network.
Then the "SMTP server" option in DASYLab is the IP address in the local network, e.g. 192.168.1.10 (I am not sure, if an alias like \\Betelgeuse-Mail will work).
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(5,701 Views)
