DASYLab
Dasylab with external op-amp
Hello dasylab users!
We are three students E-technology at Hogeschool van Amsterdam, based at Amsterdam, The Netherlands.
We are working on a sound device and we need to know if it's possible to connect an external op-amp with dasylab, to amplify a signal out of it.
Its important to amplify it outside of dasylab so, no software based amplifiers!
Dasylab version: Dasylab 8.0 Student Version.
Thanks in advance!
(5,968 Views)
So, you're using the Sound Card driver?
It uses the normal windows sound card inputs, so, if you can connect your amplifier from the source to the normal jack on the computer, you should be able to use it.
Note that the windows sound system does apply some filtering. I'm not sure of the specs - it may depend on your audio system.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,960 Views)
Hello there,
Sorry for the late reply,
Using the normal jack on the computer is not a option for us, as we use it for sound output.
We were able to find a usb soundcard with an input and output jack. We think this will solve the problem.
Thank you for the quick reply, if you have any other suggestions they are more than welcome
- E-tech
(5,946 Views)
