DASYLab
Data filtration with dasylab
Thank you again M. CJ for your feedback.
I think I was not clear enough in my description of the problem.
on the photo we notice the signal peaks in high amplitude (blue color), as well as those in low amplitude (green color). The goal is to record the pikes separately, file 1 for high amplitudes peaks, and file 2 for small ones.
In the program you suggested to me, it simply defines the peaks of the signal. this was i aleardy do by combining min/max fonction (ttl output) to relay.
Message 11 of 26
(4,076 Views)
That example split the signal using the rectangular signal in the file.
If that doesn't do it for you, then you need to provide the criteria for how you distinguish the high pressure from the low pressure.
Of course you can see it on the signal, but DASYLab isn't AI -- it needs criteria to split the signal.
I've tried a couple of other things, but this was the best.  Looking at the rectangular signal, it doesn't line up on the high peaks only.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 12 of 26
(4,070 Views)
Accepted by topic author aboom
If I have a threshold range defined (I used global variables and -110 and 110 as the low pressure range), you can do this.
The blue and green values are in two different channels, which can now be saved to individual files (not the same file).
Message 13 of 26
(4,067 Views)
Thank very much M. CJ, this is exactly what i was searching for. I did the modification to get 4 output fil, the formula fonction work perfectly. Instead of the high and low value, I replaced by percentage.
I tried differents methods before ( mean, comparate, .. ) i always loose some data. this way work perfectly.
Message 14 of 26
(4,047 Views)
Im back with another problem with this project.
I add a start stop trigger and counter to have the cycle number, and coupled the relay to get the number with the peaks value, but i get error on the relay module.
" the time information or block lenght of the input channels do not match. The channels cannot be lineked in this module. STOP"
I did the same process in my old project ( the mean methode and comparator) and its worked normaly.
What I forget ?
Message 15 of 26
(4,035 Views)
The output of the min/max is single values, at irregular intervals.
The input of the Relay has a control input and a data input. The Relay expects both to have the same timing characteristics (sample rate, block size, start time). That's why it won't work.
Can you attach an example worksheet? Perhaps my example modified to show the error?
Message 16 of 26
(4,032 Views)
attached the example (your's with the modification).
i did it for one relay to test.
Message 17 of 26
(4,027 Views)
Your data file has three channels. The previous one was two channels. Can you upload the new file?
Message 18 of 26
(4,024 Views)
Its the same file, just cannot read the forst one ( some issues with read module) so i changed it to .txt with three channels to visualize the signal. Attached the modified file.
Message 19 of 26
(4,020 Views)
I cannot test the attached, but it should work.
Split the counter from the rest of the logic, store the result in a global variable (#3). I fixed the counter to count rising edges cumulatively.
Each Relay has different timing, so you need four Read Variable modules, one for each Relay. Use one of the other Relay inputs to give the Read Variable a time signal.
Message 20 of 26
(4,015 Views)
