DASYLab
Determine the data of the Time Channel for a maximum and minimum value.
I'm am trying to display the time difference between the maximum and minimum point of a measurement.
I'm measuring the stroke and the speed of an actuator. The length of the stroke isn't a problem, this can easily be done with a maximum value.
However the point in time when the extension stops seems to be a problem. I have tried many possibilities but it won't work.
Isn't there a possibility to determine the time of the aqcuired maximum signal and displaying it on the screen?
(5,709 Views)
"I'm am trying to display the time difference between the maximum and minimum point of a measurement."
Try this to determine the time between a min and a max (or vice versa) -> attached worksheet.
The displayed signal (->image)  is a 0.5 Hz sine curve, so the time between min->max (and max->min) is one second.
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(5,703 Views)
