DASYLab
File Write > 16 Channels & loss of original channel names
Hi, I am trying to find a way of writing >>16 channels of data ALL WITH UNIQUE CHANNEL NAMES (preferably in 'Diadem' format) using a file write module.
The merge/multiplex module allows up to 16 channels to be combined into 1 giving the file write module a max throughput of 256 channels. However, either the merge module (or file write module??) changes the original channel names & replaces them with names based upon the name of the first channel concatenated with a number relating to the actual channel itself.
So, e.g. if you feed 4 channels of data via a merge module into a single channel of a file write module and the channel names are as shown below, the names created in the file will appear thus.....
Channel Original Name Name created
Ch0 Data_A Data_A
Ch1 Data_B Data_A1
Ch2 Data_C Data_A2
Ch3 Data_D Data_A3
Have I missed something or, is it impossible to achieve what I’m trying to do?
In my particular application, it is IMPERATIVE that I maintain the original channel names!
Paul Towle.
(8,192 Views)
Paul (or anyone??),
Is there an answer on this matter, I am having the same problem as Paul.
BR
Tobias Karlsson
(7,830 Views)
Hi Tobias,
I never received any feedback from the guys at Dasylab (DasyTec/NI) about this issue.
Since seeing your posting, I've asked them again (because a solution to this would be good!)
In the meantime, I guess we'll just have to wait!!
How are you progressing with your use of IXXAT CAN interfaces and Dasylab?? (Perhaps I can have your e-mail address & we can liaise direct??)
Paul Towle.
(7,822 Views)
If you look in the Write Data module Options dialog, at the very bottom is a way to configure the name of the channel. It defaults to the DASYLab channel name, which, as you've noticed, gets lost when you merge channels.
Set up a global string for each channel name, then use this dialog to link each channel with the correct string.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,791 Views)
