DASYLab
Frequency output of 6036E with NI-DAQmx
I have been using DAQCard-6036E frequency output for simulations with DASYlab 8.00.04. Now I purchased USB-6009 to use together with the existing card. I had to upgrade to NI-DAQmx as well as to DASYLab NI-DAQmx driver to be able to use the 6009. The problem is that now I can not use the 6036E frequency output like before. There seems to be no way to vary the frequency or duty cycle from Dasylab anymore. I could not find any settings from NI-DAQmx pulse output task setup to enable this function?
(7,558 Views)
Hello, we have recognized your frequency output usage problem. With next DASYLab NI-DAQmx driver release it's possible to define the NI-DAQmx task name also with a Global String. Then you can define a number of frequency output tasks under MAX and choose one of the tasks with a Global String with start from worksheet. A direct parameter setting from frequency or High / Low time windows over DASYLab modul inputs are not planed and also for technical reasons not possible.
(7,534 Views)
