DASYLab
Gain Queue
I get the following message if I try to activate channel 0 and then 5 and 6. Not if I use channels in order.
How do I access the gain queue list and fix the error?
(I use Dasylab 2022 and USB-1808X),
Thank you,
(3,899 Views)
I'd like to know why the USB-1808X requires the channels to be in order when our other devices do not. I checked the USB-1608FS-Plus, a simultaneous input device similar to the USB-1808X, and it did not have this problem. The workaround is to read all the channels and ignore the ones you don't want.
(3,889 Views)
