DASYLab
How do I create a pull up voltage as a control signal?
I'm using a Statistics Minimum/Maximum module, but cannot route the analog data to all 16 inputs that I need from this module (I'm guessing a current drive limitation, although I don't know why this would be needed in software). My first thought was to use an Amplitude Controlled Signal Router to expand the 15th occurrence of the signal to 16. It seems that since I want the Signal router to always be active (ON) that I would want to pull up the Signal Router's control input. How to I create a pull up which is common in digital electronics for this purpose?
(6,532 Views)
Accepted by topic author Williamx
It's not a current drive limitation, but merely that you can only branch a wire 15 times, for up to 16 destinations. You can get around this by putting a Scaling module, set to NOP, and then using its output for up to 16 more destinations.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,527 Views)
Excellant CJ! Thanks very much!
(6,518 Views)
